求助
浏览:11460 回答:1
simufact分析转向节时的错误日志DATE :06-05-15 TIME :14:54:56
%I-P1018427-NAS_PUT_GLOBAL_PARAMS_ON_NIF, , ,
INPUT DECK: WithFlashFv3D.dat
LINE #25 : PARAM,HAMMER
MESSAGE : Hammer type simulation activated by PARAM,HAMMER
Endtime and edit times will be interpreted as percentage of
lost hammer energy.
%I-P2149003-P2XXTXIX_PACKET_OPTION_UNITS, , ,
SI-unit system is defined: m,kg,sec,k
%I-P2148701-P2XXTXIX_PACKET_OPTION_HEATXFR, , ,
Heat transfer activated by PARAM,HEATXFR.
%I-P2122628-P2XXTXIX_PACKET_HOT_YIELD, , ,
Fraction of mechanical work that will be converted to heat is
set equal to 0.90000
%I-P2022803-P2XXTXIX_SET_GLOBAL_DEFAULT, , ,
No minimum time step defined , so 10% of initial time step will be used
%I-P2178301-P2_COUNT_REQ_MEMSIZE, , ,(13),
MEMORY SIZE ESTIMATE:
3900588 INTEGER WORDS
2075542 FLOAT WORDS
ABOVE SIZE USED IN CORE-MEMORY ALLOCATION.
%W-P2108906-P2_DEFINE_VARIABLES_FOR_EDIT, , ,
Variable CONTACT is not legal in input set FV_WORKPIECE and is
therefore ignored.
This may result in an empty edit set.
Variable NORSTS is not legal in input set FV_WORKPIECE and is
therefore ignored.
Variable LUBE is not legal in input set FV_WORKPIECE and is
therefore ignored.
Variable DIEFILL is not legal in input set FV_WORKPIECE and is
therefore ignored.
%I-P3002405-P3_CHECK_POLYH_SURF_VOL, , ,
Volume covered by SURFACE SURFACE3 is 0.65681E-03
%I-P3002404-P3_CHECK_POLYH_SURF_VOL, , ,
Area of surface SURFACE3 is 0.62812E-01
%W-P3116501-V3_REVERSE_POLYH_V3, , ,
A side of a face in surface SURFACE1 has no other faces attached.
This indicates a hole in the surface.
%W-P3116502-V3_REVERSE_POLYH_V3, , ,
Program error:
Inconsistent sorting of faces of COUPLING surface SURFACE1
Program error:
%C-P3154104-V3_STORE_POL_SIDES, , ,
Die or workpiece surface contains holes or T-joins.
Surface: SURFACE1
WITHFLASHFV3D
Simufact 11.0 Windows x64
SUMMARY OF MESSAGES (INCLUDING NON-PRINTED MESSAGES)
INFORMATIVE : 8
WARNINGS : 7
CATASTROPHIC ERRORS : 1
lost hammer energy.
2075542 FLOAT WORDS
therefore ignored.
therefore ignored.
therefore ignored.
therefore ignored.
Program error:
Program error:
Surface: SURFACE1
WITHFLASHFV3D
INFORMATIVE : 8
WARNINGS : 7
Hubert.Wang
