网格划分问题
浏览:16184
网格划分时 出现信息提示错误:
The following surfaces cannot be meshed with acceptable quality .try using a different element size or virtual or virtual topology.
A mesh could not be generated using the current meshing options and seting .......
各位大神怎么解决
