求助高手帮忙看看ansys二维 永磁铁 励磁线圈复合磁场仿真不收敛的问题,十分感激!
浏览:7133 回答:1
我做的是一个永磁铁和载流线圈共同作用的一个二维静态 电磁场分析,但是总是出不来结果,由于本人论文较急,还望有高手可以指点一下,小弟十分感谢!
这是机械结构图
这是有限元模型图,A4,A5为通入电流相反的线圈区域,A6,A7区域为磁极相反的永磁铁
下面是我的有限元仿真程序
/prep7
ET,1,PLANE13 ! 指定单元
KEYOPT,1,3,1 ! 指定分析类型为轴对称
EMUNIT,MKS !单位制
TB,BH, 1, , 14 ! 磁流变液BH曲线
TBPT,DEFI, 18000, 0.125
TBPT,, 35000, 0.25
TBPT,, 47000, 0.375
TBPT,, 61000, 0.5
TBPT,, 85000, 0.625
TBPT,, 120000, 0.75
TBPT,, 155000, 0.875
TBPT,, 200000, 1
TBPT,, 255000, 1.125
TBPT,, 330000, 1.25
TBPT,, 419000, 1.375
TBPT,, 502000, 1.5
TBPT,, 600000, 1.625
TBPT,, 705000, 1.75
TB,BH, 2, , 19 ! 缸体、活塞杆(45#)BH曲线
TBPT,DEFI, 410, 0.05
TBPT,, 790, 0.1
TBPT,, 1150,0.2
TBPT,, 1450,0.3
TBPT,, 1650,0.4
TBPT,, 1850,0.5
TBPT,, 2200,0.6
TBPT,, 2420,0.7
TBPT,, 2762,0.8
TBPT,, 2950,0.9
TBPT,, 3220,1
TBPT,, 3680,1.1
TBPT,, 4380,1.2
TBPT,, 5150,1.3
TBPT,, 6300,1.4
TBPT,, 8400,1.5
TBPT,, 11580, 1.6
TBPT,, 16000, 1.7
TBPT,, 24800, 1.85
TB,BH, 3, , 27 ! 活塞(电工纯铁) BH曲线
TBPT,DEFI,33,0.1
TBPT,, 71.8,0.22
TBPT,, 101.1,0.31
TBPT,, 150,0.46
TBPT,, 179.4,0.55
TBPT,, 212,0.65
TBPT,, 248,0.76
TBPT,, 298.2,0.89
TBPT,, 386.5,1.02
TBPT,, 513.6,1.15
TBPT,, 665.3,1.27
TBPT,, 753.6,1.33
TBPT,, 911.5,1.41
TBPT,, 1119.6,1.45
TBPT,, 1471.3,1.53
TBPT,, 1884,1.57
TBPT,, 2334.8,1.6
TBPT,, 2888.8,1.63
TBPT,, 4039,1.67
TBPT,, 5206.3,1.7
TBPT,, 83353,1.76
TBPT,, 10048,1.79
TBPT,, 13098,1.84
TBPT,, 15850,1.88
TBPT,, 21044,1.94
TBPT,, 35168,2.06
TBPT,, 37680,2.0
MP,MURX,4,1 ! 线圈
MP,MURX,5,1
MP,MURX,6,1.415 ! 永磁铁相对磁导率
MP,MGXX,6,-450e3 ! 永磁铁矫顽力
MP,MURX,7,1.415
MP,MGXX,7,450e3
/PNUM,AREA,1 ! 建模
RECTNG,0,0.06,0,0.009
RECTNG,0,0.06,0.009, 0.009+0.0045
RECTNG,0,0.01,0.009+0.0045, 0.057/2
RECTNG,0.01,0.05, 0.009+0.0045, 0.009+0.0045+0.004
RECTNG,0.01,0.05, 0.009+0.0045+0.004, 0.009+0.0045+0.004+0.0095
RECTNG,0.05,0.06, 0.009+0.0045, 0.057/2
RECTNG,0,0.06, 0.06/2, 0.074/2
ARSYM,x,all ! 镜像
AADD,1,8
AADD,6,2,3,10,9,13
AADD,7,14
AGEN,2, all, , , 0.06, , , , 1, 1 ! 坐标轴移动到端部
RECTNG,0,0.12,0, 0.074/2
AOVLAP,all
NUMCMP,AREA
APLOT
asel,s,,,7 ! 赋予材料
磁流变液
AATT,1, 1, 1
asel,s,,,1 ! 赋予材料
缸体,活塞杆
asel,a,,,6
AATT,2, 1, 1
asel,s,,,8 ! 赋予材料
活塞
AATT,3, 1, 1
asel,s,,,2, ! 赋予材料
线圈
AATT,4, 1, 1
asel,s,,,4,
AATT,5, 1, 1
asel,s,,,3 ! 赋予材料
永磁铁
AATT,6, 1, 1
asel,s,,,5
AATT,7, 1, 1
/PNUM,MAT,1 ! 打开材料编号
allsel,all
APLOT
SMRTSIZE,2 ! 智能网格等级
AMESH,ALL ! 划分网格
FINISH
/solu
n=325 ! 线圈匝数
i1=1 ! 电流
wc=0.04
hc=0.0095
acoil=wc*hc
jdens1=n*i1/acoil ! 电流密度
ESEL,S,MAT,,4 ! 选择线圈单元
BFE,ALL,JS,,,,-jdens1 ! 电流载荷
ESEL,S,MAT,,5 ! 选择线圈单元
BFE,ALL,JS,,,,jdens1 ! 相反电流载荷
allsel,all
NSEL,EXT ! 选择外层所有节点
D,ALL,AZ,0 ! 施加磁力线平行边界条件
Magsolv,0,3,0.001,,25 ! 求解
FINISH
/POST1
PLF2D ! 磁力线图
PLVECT,B,, , ,VECT,ELEM,ON,0 ! 磁流密度矢量图
PLNSOL,B,SUM, 0 ! 磁通密度等值云图
程序有什么错误还希望高手指点。
liusongoku
不收敛最常见就是磁铁的非线性设置的不太合理。建议弄准磁铁的矫顽力剩磁等参数。
模型剖分上也要注意过渡均匀,最好加上远场单元。
2015年9月16日
