求助:matlab调用abaqus出错
浏览:10921
在matlab里利用system(['abaqus ','job','=main']) 命令调用abaqus作计算,结果生成报错的log文件:
Abaqus JOB D:\abquasworking\pipe
Abaqus 6.13-1
Abaqus Error: Unable to create a temporary directory "D:\Temp\Administrator_D:\abquasworking\pipe_7708" to be used for scratch files.
Abaqus/Analysis exited with errors
请问如何解决这个问题?
