梁仿真问题
浏览:9200 回答:1
再做压电梁仿真的过程中,出现以下错误,请各位大侠指教,Anisotropic material properties without a local orientation system have been defined for 18000 elements. Anisotripic material properties must be defined in a local orientation system. The elements are identified in element set ErrElemAnisotropicMaterial.
墨萦
在property-设置了材料的方向,参考https://www.sohu.com/a/143810570_744423
2021年2月7日
