求助ABAQUS模拟螺栓连接!!
浏览:14073 回答:1
各位大神,新手求救。。要求做一个挂墙架的螺栓连接分析,简单分割了一下几何元素画网格,求解的时候为何一直显示The volume of 16 elements is zero, small, or negative. Check coordinates or node numbering, or modify the mesh seed. In the case of a tetrahedron this error may indicate that all nodes are located very nearly in a plane. The elements have been identified in element set ErrElemVolSmallNegZero.
curry0023
为何无人问津……大神们帮帮忙啊……
2015年10月8日
