看看计算不下去了,计算到倒数第三步的时候出现的问题,大家看看如何解决,
浏览:147582 回答:9
s t o r a g e a l l o c a t i o n
Memory required to begin solution : 200652469
Additional dynamically allocated memory: 2015051
Total: 202667520
93817 t 1.0132E-01 dt 1.08E-06 flush i/o buffers
*** WARNING plasticity algorithm did not converge for MAT36
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 2 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 2 elements
for 2 elements
for 1 elements
for 1 elements
for 3 elements
for 1 elements
for 1 elements
for 3 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 2 elements
for 1 elements
for 1 elements
for 2 elements
for 2 elements
for 1 elements
for 1 elements
for 1 elements
for 2 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 3 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 3 elements
for 3 elements
for 1 elements
for 2 elements
for 1 elements
for 2 elements
for 1 elements
for 1 elements
for 1 elements
for 2 elements
for 1 elements
for 1 elements
node # 1 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 2 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 3 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 4 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 5 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 6 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 7 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 8 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 9 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 10 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 11 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 12 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 13 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 14 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 15 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 16 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 17 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 18 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 19 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 20 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 21 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 22 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 23 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 24 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 25 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 26 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 27 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 28 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 29 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
node # 30 has out-of-range velocities
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
94950 t 1.0255E-01 dt 1.74E-06 write d3plot file
E r r o r t e r m i n a t i o n
Memory required to complete solution : 200652469
Total: 202667520
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 7.5600E+02 1.49 7.5789E+02 1.49
Element processing ... 2.6268E+04 51.79 2.6211E+04 51.68
Binary databases ..... 9.0000E+00 0.02 8.2860E+00 0.02
ASCII database ....... 4.0000E+00 0.01 5.3160E+00 0.01
Contact algorithm .... 2.3636E+04 46.60 2.3684E+04 46.70
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 4.7000E+01 0.09 5.0622E+01 0.10
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 5.0720E+04 100.00 5.0717E+04 100.00
Problem time = 1.0255E-01
Problem cycle = 94950
Total CPU time = 50720 seconds ( 14 hours 5 minutes 20 seconds)
CPU time per zone cycle = 1265 nanoseconds
Clock time per zone cycle= 1265 nanoseconds
Number of CPU's 1
NLQ used/max 96/ 96
Start time 01/20/2008 14:01:06
End time 01/21/2008 04:06:49
Elapsed time 50743 seconds( 14 hours 5 min. 43 sec.) for 94950 cycles
Total: 202667520
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 2 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 2 elements
for 2 elements
for 1 elements
for 1 elements
for 3 elements
for 1 elements
for 1 elements
for 3 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 2 elements
for 1 elements
for 1 elements
for 2 elements
for 2 elements
for 1 elements
for 1 elements
for 1 elements
for 2 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 3 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 1 elements
for 3 elements
for 3 elements
for 1 elements
for 2 elements
for 1 elements
for 2 elements
for 1 elements
for 1 elements
for 1 elements
for 2 elements
for 1 elements
for 1 elements
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
x-velocity= NaN
y-velocity= NaN
z-velocity= NaN
Total: 202667520
Number of CPU's 1
NLQ used/max 96/ 96
