ansys接触问题求助
浏览:184145 回答:4
the value of uy at node 386 is 1026284.97. it is greater than the current limit of 1000000.this generally indicates rigid body motion as a result of an unconstrained model.verify that your model is properly constrained
message continuation diagnostic information
if one or more parts of the model are held together only by contact verify that the contact surface are closed.you can check contact status in the solution module for the converger solution using cncheck
我是做的型钢插入混凝土剪力墙节点的承载力分析(型钢与墙同走向、非直交) 考虑插入部分二者的接触 型钢取shell63 混凝土取solid65 网格尺寸取50 在混凝土墙底部约束所有自由度 在钢梁外伸悬臂端加竖向荷载 用接触单元conta170、174定义接触对 问题可能出现在哪呢
