Ansys An unexpected error ( SIG$SEGV ) has occurred
浏览:122035 回答:6
进行瞬态分析遇到如下问题:不知什么原因,哪位大神能告诉小弟一下
*** WARNING *** CP = 8.720 TIME= 22:26:30
Some of the defined and selected elements did not require fluid solid
interface. Use the SFELIST,ALL,FSIN command to view a list of
elements that did have fluid solid interface stored.
*** WARNING *** CP = 10.062 TIME= 22:26:30
*** WARNING *** CP = 11.154 TIME= 22:26:31
Element shape checking is currently inactive. Issue SHPP,ON or
SHPP,WARN to reactivate, if desired.
*** WARNING *** CP = 31.465 TIME= 22:27:45
The closed gap/penetration is larger than the pair based pinball.
Please verify the pinball carefully.
The closed gap/penetration may be too large. Increase pinball if it is
a true closed gap/penetration. Decrease pinball if it is a false one.
*** WARNING *** CP = 18.767 TIME= 22:26:33
Material number 12 (used by element 242891 ) should normally have at
least one MP or one TB type command associated with it. Output of
energy by material may not be available.
*** WARNING *** CP = 3422.818 TIME= 22:51:04
The closed gap may be too large. Increase pinball if it is a true
closed gap. Decrease pinball if it is a false one.
For total 1285 contact elements, there are 171 elements are in contact.
There are 171 elements are in sticking.
Contacting area 4.00928488.
Max. Pinball distance 9.684929262E-02.
One of the contact searching regions contains at least 10 target
elements.
Max. Pressure/force -1.577475372E-07.
Max. Normal stiffness 14800661.4.
Min. Normal stiffness 14800661.4.
Max. Tangential stiffness 844352.746.
Min. Tangential stiffness 844352.746.
*** ERROR *** CP = 42914.348 TIME= 15:18:45
A System Coupling error occurred while the request AssignToken was
being served.
An unexpected error ( SIG$SEGV ) has occurred... ANSYS internal data
has been corrupted. ANSYS is unable to recover and will terminate.
Previously saved files are unaffected. Please send the data leading
to this operation to your technical support provider, as this will
allow ANSYS, Inc to improve the program.
Current ANSYS Traceback:
CP_ErrorHandler
CP_ServeUntil
CP_GetLoadData
svkan
solvcl
ANSYS
elements.
being served.
CP_ErrorHandler
CP_ServeUntil
CP_GetLoadData
svkan
solvcl
ANSYS
