- matlab与ansys数据传递? 1个回答
我用ansys建了模型并做了有限元分析,现在需要把它用到matlab里,遇到了matlab与ansys互相调用的问题,我先假设2和7两个单元的损伤,损伤程度分别为0.3和0.2,我把它们用matlab写入了txt文件中,然后再用ansys调用计算这种损伤情况下的频率,这是我的matlab程序 a=[2;7;0.3;0.2]; fid = fopen('b.txt','wt'); fprintf(f
- ansys一段代码,关于平板焊接的,运行有问题,精通ansys的大神能帮着修改一下吗 暂无回答
ET,1,SOLID70 BLOCK,0,0.08,0,0.09,0,0.006 BLOCK,0.08,0.17,0,0.09,0,0.006 BLOCK,0.17,0.19,0,0.09,0,0.006 BLOCK,0.19,0.3,0,0.09,0,0.006 VGLUE,ALL MPTEMP,1,20,100,300,400,500,700 MPTEMP,7,900,1470,1550,16
- 带预紧力的螺栓连接ANSYS分析 2个回答
求助大神帮我看看是哪里出了问题,我按照这个命令流做的,但是最后在求解出现问题,没法显现应力应变图。 /CLEAR /FILNAME,EXAMPLE47_1 /PREP7 ET,1,SOLID186 ET,2,TARGE170 ET,3,CONTA174 R,1,,,0.1 R,2,,,0.1 R,3,,,0.1 MP,EX,1,2E11 MP,PRXY,1,0.3 /VIEW,1,1,1,1 CY
谢谢,,我觉得对于电压来说也是指的全约束,不过我对这个全约束还是不是很理解。。。。。什么时候需要加这个全约束啊??
