- 技术邻 >
- CAE仿真 >
- HyperWorks
新手-Ansys Mechanical Magnetostatic 分析报错
Solver Output
ANSYS Multiphysics
| W E L C O M E T O T H E A N S Y S (R) P R O G R A M |
* ANSYS 14.5 LEGAL NOTICES *
* Copyright 2012 SAS IP, Inc. All rights reserved. *
* Unauthorized use, distribution or duplication is *
* prohibited. *
* Ansys is a registered trademark of ANSYS, Inc. or its *
* subsidiaries in the United States or other countries. *
* See the ANSYS, Inc. online documentation or the ANSYS, Inc. *
* documentation CD or online help for the complete Legal *
* Notice. *
* THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION *
* INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY *
* PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS. *
* The software products and documentation are furnished by *
* ANSYS, Inc. or its subsidiaries under a software license *
* agreement that contains provisions concerning *
* non-disclosure, copying, length and nature of use, *
* compliance with exporting laws, warranties, disclaimers, *
* limitations of liability, and remedies, and other *
* provisions. The software products and documentation may be *
* used, disclosed, transferred, or copied only in accordance *
* with the terms and conditions of that software license *
* agreement. *
* ANSYS, Inc. is a UL registered *
* ISO 9001:2008 company. *
* This product is subject to U.S. laws governing export and *
* re-export. *
* For U.S. Government users, except as specifically granted *
* by the ANSYS, Inc. software license agreement, the use, *
* duplication, or disclosure by the United States Government *
* is subject to restrictions stated in the ANSYS, Inc. *
* software license agreement and FAR 12.212 (for non-DOD *
* licenses). *
***** ANSYS COMMAND LINE ARGUMENTS *****
BATCH MODE REQUESTED (-b) = NOLIST
INPUT FILE COPY MODE (-c) = COPY
2 PARALLEL CPUS REQUESTED
START-UP FILE MODE = NOREAD
STOP FILE MODE = NOREAD
00694185 VERSION=WINDOWS x64 RELEASE= 14.5 UP20120918
CURRENT JOBNAME=file 20:42:26 MAY 28, 2013 CP= 0.969
PARAMETER _DS_PROGRESS = 999.0000000
/INPUT FILE= ds.dat LINE= 0
DO NOT WRITE ELEMENT RESULTS INTO DATABASE
*GET _WALLSTRT FROM ACTI ITEM=TIME WALL VALUE= 20.7072222
TITLE=
Lev--Magnetostatic (A5)
SET PARAMETER DIMENSIONS ON _WB_PROJECTSCRATCH_DIR
TYPE=STRI DIMENSIONS= 248 1 1
PARAMETER _WB_PROJECTSCRATCH_DIR(1) = C:\Users\Lei\Dropbox\MIT\Research\Analysis\Ansys\Lev\_ProjectScratch\Scr230A\
SET PARAMETER DIMENSIONS ON _WB_SOLVERFILES_DIR
PARAMETER _WB_SOLVERFILES_DIR(1) = C:\Users\Lei\Dropbox\MIT\Research\Analysis\Ansys\Lev\Lev_files\dp0\SYS\MECH\
SET PARAMETER DIMENSIONS ON _WB_USERFILES_DIR
PARAMETER _WB_USERFILES_DIR(1) = C:\Users\Lei\Dropbox\MIT\Research\Analysis\Ansys\Lev\Lev_files\user_files\
--- Data in consistent MKS units.
MKS UNITS SPECIFIED FOR INTERNAL
LENGTH (l) = METER (M)
MASS (M) = KILOGRAM (KG)
TIME (t) = SECOND (SEC)
TEMPERATURE (T) = CELSIUS (C)
TOFFSET = 273.0
CHARGE (Q) = COULOMB
FORCE (f) = NEWTON (N) (KG-M/SEC2)
HEAT = JOULE (N-M)
PRESSURE = PASCAL (NEWTON/M**2)
ENERGY (W) = JOULE (N-M)
POWER (P) = WATT (N-M/SEC)
CURRENT (i) = AMPERE (COULOMBS/SEC)
CAPACITANCE (C) = FARAD
INDUCTANCE (L) = HENRY
MAGNETIC FLUX = WEBER
RESISTANCE (R) = OHM
ELECTRIC POTENTIAL = VOLT
INPUT UNITS ARE ALSO SET TO MKS
***** ANSYS - ENGINEERING ANALYSIS SYSTEM RELEASE 14.5 *****
ANSYS Multiphysics
00694185 VERSION=WINDOWS x64 20:42:26 MAY 28, 2013 CP= 1.016
***** ANSYS ANALYSIS DEFINITION (PREP7) *****
*********** Nodes for the whole assembly ***********
*********** Elements for Body 1 "Rotor:1" ***********
*********** Elements for Body 2 "levitation_core:1" ***********
*********** Elements for Body 3 "levitation_coil_half:1" ***********
*********** Elements for Body 4 "levitation_coil_half:2" ***********
*********** Elements for Body 5 "Solid" ***********
*********** Send User Defined Coordinate System(s) ***********
*********** Set Reference Temperature ***********
*********** Send Materials ***********
*********** Send Named Selection as Node Component ***********
*********** Set KEYOP for Solid Conductors ***********
*********** Create FluxPar ***********
*********** Create Coil Current ***********
***** ROUTINE COMPLETED ***** CP = 3.047
--- Number of total nodes = 210679
--- Number of contact elements = 0
--- Number of spring elements = 0
--- Number of bearing elements = 0
--- Number of solid elements = 136592
--- Number of total elements = 136592
*GET _WALLBSOL FROM ACTI ITEM=TIME WALL VALUE= 20.7075000
************************* SOLUTION ********************************
***** ANSYS SOLUTION ROUTINE *****
WRITE ALL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
FOR ALL APPLICABLE ENTITIES
******************* SOLVE FOR LS 1 ****************
SPECIFIED BODY FORCE JS FOR ALL PICKED ELEMENTS AT STARTING LOCATION 2
IS SET ACCORDING TO TABLE PARAMETER = _LOADVARI162
IS SET ACCORDING TO TABLE PARAMETER = _LOADVARI230
USE AUTOMATIC TIME STEPPING THIS LOAD STEP
USE 1 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL DEGREES OF FREEDOM
FOR AUTOMATIC TIME STEPPING:
USE 10 SUBSTEPS AS A MAXIMUM
USE 1 SUBSTEPS AS A MINIMUM
TIME= 1.0000
ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.
WRITE ALL ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE
WRITE ALL ITEMS TO THE DATABASE WITH A FREQUENCY OF LAST
CONVERGENCE ON CSG BASED ON THE NORM OF THE N-R LOAD
WITH A TOLERANCE OF 0.5000E-02 AND A MINIMUM REFERENCE VALUE OF 0.1000E-05
USING THE L2 NORM (CHECK THE SRSS VALUE)
*GET ANSINTER_ FROM ACTI ITEM=INT VALUE= 0.00000000
*IF ANSINTER_ ( = 0.00000 ) NE
0 ( = 0.00000 ) THEN
*ENDIF
***** ANSYS SOLVE COMMAND *****
*** TREE GAUGING FOR EDGE ELEMENTS ***
*** ERROR *** CP = 4.328 TIME= 20:42:28
*** GAUGE command aborted ***
NUMBER OF WARNING MESSAGES ENCOUNTERED= 0
NUMBER OF ERROR MESSAGES ENCOUNTERED= 1
***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
+--------------------- A N S Y S S T A T I S T I C S ------------------------+
Release: 14.5 Build: UP20120918 Platform: WINDOWS x64
Date Run: 05/28/2013 Time: 20:42
Windows Process ID: 4968
Processor Model: Intel(R) Core(TM) i5-3330S CPU @ 2.70GHz
Compiler: Intel(R) FORTRAN Compiler Version 11.1.0 (Build: 20100414)
Microsoft(R) Visual C/C++ Compiler Version 15.0 (Build: 30729)
Intel(R) Math Kernel Library Version 10.3.3 Product Build 20110314
Total number of cores available : 4
Number of physical cores available : 4
Number of cores requested : 2 (Shared Memory Parallel)
GPU Acceleration: Not Requested
Job Name: file
Working Directory: C:\Users\Lei\Dropbox\MIT\Research\Analysis\Ansys\Lev\_ProjectScratch\Scr230A
Total CPU time for main thread : 3.6 seconds
Total CPU time summed for all threads : 4.3 seconds
Elapsed time spent pre-processing model (/PREP7) : 1.6 seconds
Elapsed time spent solution - preprocessing : 0.0 seconds
Elapsed time spent computing solution : 0.0 seconds
Elapsed time spent solution - postprocessing : 0.0 seconds
Elapsed time spent post-processing model (/POST1) : 0.0 seconds
Maximum total memory used : 363.0 MB
Maximum total memory allocated : 1088.0 MB
Maximum total memory available : 8 GB
+------------------ E N D A N S Y S S T A T I S T I C S -------------------+
| ANSYS RUN COMPLETED |
| Release 14.5 UP20120918 WINDOWS x64 |
| Database Requested(-db) 512 MB Scratch Memory Requested 512 MB |
| Maximum Database Used 131 MB Maximum Scratch Memory Used 232 MB |
| CP Time (sec) = 4.328 Time = 20:42:28 |
| Elapsed Time (sec) = 5.000 Date = 05/28/2013 |
