ls-dyna分析时遇到错误,求教高手
浏览:63812 回答:1
在做一个船舶砰击的分析,求解.K文件时遇到错误求高手指导。
d3hp文件:
Date: 07/20/2013 Time: 23:26:19
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version : ls971s R6.0.0 Date: 01/24/2012 |
| Revision: 71482 Time: 10:05:53 |
| Features enabled in this version: |
| Shared Memory Parallel |
| ANSYS Database format |
| ANSYS License (ANSYS145) |
| Licensed to: |
| Platform : Xeon64 System |
| OS Level : Linux 2.6.9 |
| Compiler : Intel Fortran Compiler 10.1 |
| Hostname : localhn3 |
| Precision : Single precision (I4R4) |
| SVN Version: 71488 |
| Unauthorized use infringes LSTC copyrights |
Input file: /home/douyizhe/work1/slamming/1.k
The native file format : 32-bit small endian
Memory size from default : 20000000
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Finite Element code. *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2012 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
LS-DYNA will perform a structural only analysis
5*KEYWORD
code input version =1987
code revision =902
formats =small
*** Error 20001 (STR+1)
input error found
reading 1st control card
line number 3 contains improperly formatted data
**************************************** line# 3
analyse of slamming model
E r r o r t e r m i n a t i o n 07/20/13 23:26:19
S t o r a g e a l l o c a t i o n
Memory required to complete solution : 0
Additional dynamically allocated memory: 20
Total: 20
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 1.9193E-04 100.00 1.9400E-04 100.00
Element processing ... 0.0000E+00 0.00 0.0000E+00 0.00
Binary databases ..... 0.0000E+00 0.00 0.0000E+00 0.00
ASCII database ....... 0.0000E+00 0.00 0.0000E+00 0.00
Contact algorithm .... 0.0000E+00 0.00 0.0000E+00 0.00
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 1.9193E-04 100.00 1.9400E-04 100.00
Problem time = 0.0000E+00
Problem cycle = 0
Total CPU time = 0 seconds ( 0 hours 0 minutes 0 seconds)
CPU time per zone cycle = 0 picoseconds
Clock time per zone cycle= 0 picoseconds
Number of CPU's 1
NLQ used/max 384/ 384
Start time 07/20/2013 23:26:19
End time 07/20/2013 23:26:19
Elapsed time 0 seconds( 0 hours 0 min. 0 sec.) for 0 cycles
message文件:
| www.lstc.com |
| Licensed to: |
expanding memory to 20000000 starting ls-dyna
* results. *
5*KEYWORD
ls-dyna ls971s.71482 R6.0.0 date 01/24/2012
input error found
Total: 20
Problem cycle = 0
Number of CPU's 1
求高手,问题出在哪儿?QQ:1182850270,谢谢!
d3hp文件:
| www.lstc.com |
| Licensed to: |
* results. *
5*KEYWORD
code revision =902
formats =small
input error found
Total: 20
Problem cycle = 0
Number of CPU's 1
message文件:
| www.lstc.com |
| Licensed to: |
* results. *
5*KEYWORD
input error found
Total: 20
Problem cycle = 0
Number of CPU's 1
input error found
提示说是格式不对,查看错误提示说明就好了
