新人求助,ansys算例
浏览:38440 回答:7
*** WARNING *** CP = 3.884 TIME= 09:48:56
Zero thickness element 1 may result in wrong thermal or bending stress.
Check real constant table 3.
Zero thickness element 9 may result in wrong thermal or bending stress.
Check real constant table 1.
Zero thickness element 17 may result in wrong thermal or bending
stress. Check real constant table 2.
这是哪的问题 我是看着例题做的 用的Beam: 2d elastic 3单元 实常数定义了截面面积和惯性矩 (不会命令流 ,所以可能表达不清楚,如果我表达不清楚,各位大神麻烦一下百度“背景素材选自位于密执安的"Old North Park Bridge" ” )
