求高手看看,运动完成后系统报错,报错是什么原因
浏览:92266 回答:2
WARNING: An Out-of-range X value has been used in the spline calculation.
Extrapolation is required for san_zi_you_du_mo_xing_jian_hua.SPLINE_1.
The X value (9.100000) should be between 0.000000 and 9.000000
Extrapolation is required for san_zi_you_du_mo_xing_jian_hua.SPLINE_2.
Extrapolation is required for san_zi_you_du_mo_xing_jian_hua.SPLINE_3.
WARNING: Additional Out-of-range warnings suppressed for san_zi_you_du_mo_xing_jian_hua.SPLINE_1.
WARNING: Additional Out-of-range warnings suppressed for san_zi_you_du_mo_xing_jian_hua.SPLINE_2.
WARNING: Additional Out-of-range warnings suppressed for san_zi_you_du_mo_xing_jian_hua.SPLINE_3.
元来是你
