ADAMS仿真报错
浏览:173208
WARNING: The symbolic refactorization failed. The matrix is structurally singular
at time = 0.16829.
at time = 0.16834.
WARNING: ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
NOTE: The set of redundant constraints has changed at time = 0.16834.
我把模型从proe中导入进去后,添加约束和驱动,然后输入了驱动函数,进行仿真时一直报这个错误,请问怎么解决啊
