橡胶沙漏的例题
浏览:16229
***WARNING: THE OPTION *BOUNDARY,TYPE=DISPLACEMENT HAS BEEN USED; CHECK STATUS
FILE BETWEEN STEPS FOR WARNINGS ON ANY JUMPS PRESCRIBED ACROSS THE
STEPS IN DISPLACEMENT VALUES OF TRANSLATIONAL DOF. FOR ROTATIONAL
DOF MAKE SURE THAT THERE ARE NO SUCH JUMPS. ALL JUMPS IN
DISPLACEMENTS ACROSS STEPS ARE IGNORED
各路大神,这个警告该在哪里着手处理呢,谢谢啦
