求助,dy仿真时出错
浏览:7225 回答:1
Date: 05/02/2015 Time: 11:47:53
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version : ls971s R5.0 Date: 04/10/2010 |
| Revision: 59419 Time: 10:11:54 |
| Features enabled in this version: |
| Shared Memory Parallel |
| ANSYS Database format |
| Licensed to: |
| Platform : WIN32 |
| OS Level : Windows XP Pro SP2 B2600003/2008 |
| Compiler : Intel Fortran Compiler 10.1 |
| Hostname : z-PC |
| Precision : Single precision (I4R4) |
| SVN Version: 59824 |
| Unauthorized use infringes LSTC copyrights |
Input file: C:/Users/ADMINI~1/Desktop/11/Untitled.dyn
The native file format : 32-bit small endian
Memory size from command line: 131072000
JOBID : Untitled
Memory option : AUTO selected
expanding memory to 131072000 starting ls-dyna
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Finite Element code. *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2010 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 1 beginning of keyword reader
expanding memory to 20720
expanding memory to 78666
expanding memory to 123666
expanding memory to 153666
expanding memory to 302898
expanding memory to 325388
expanding memory to 372796
expanding memory to 406540
expanding memory to 428250
expanding memory to 449752
expanding memory to 469752
expanding memory to 489752
expanding memory to 509752
expanding memory to 529752
expanding memory to 549752
expanding memory to 569752
expanding memory to 592114
expanding memory to 643814
Open include file: Untitled.blk
Open include file: Untitled.mod
expanding memory to 739330
expanding memory to 761450
expanding memory to 783758
expanding memory to 1084322
expanding memory to 1216282
expanding memory to 1238214
Memory required to process keyword : 1238214
contracting memory to 1 end of keyword reader
LS-DYNA will perform a structural only analysis
untitled
ls-dyna ls971s.59419 R5.0 date 04/10/2010
| www.lstc.com |
| Licensed to: |
| Platform : WIN32 |
| Hostname : z-PC |
JOBID : Untitled
* results. *
untitled
