ABAQUS金属非稳态切削过程的模拟分析
浏览:8983 回答:1
在做ABAQUS经典例题集里面的金属非稳态切削过程的模拟分析时,按照书上的步骤有好多错误,求指教啊The elements contained in element set ErrElemExcessDistortion-Step1 have distorted excessively.
Error in job Job-jinshufeiwentai: Print-out suppressed for subsequent distorted elements
Error in job Job-jinshufeiwentai: There are a total of 28 excessively distorted elements
Error in job Job-jinshufeiwentai: The ratio of deformation speed to wave speed exceeds 1.0000 in at least one element. This usually indicates an error with the model definition. Additional diagnostic information may be found in the message file.
Error in job Job-jinshufeiwentai: The elements contained in element set ErrElemExcessDistortion-Step1 have distorted excessively.
Job Job-jinshufeiwentai: Abaqus/Explicit aborted due to errors.
发条Orange
您好,同样是这个问题,请问您怎么解决的?谢谢
2024年1月26日
