workbench非线性分析中遇到的问题
浏览:3490
用workbench进行板的拉伸分析,设置好弹性模量与泊松比,采用双线性等向强化,切线模量为0,
网格划分:
采用加载位移的方法,一端固定,一端加载位移,分20步加载,开启大变形
但是最终求解总是报错,求解不出来,是为什么呢?
*** ERROR *** CP = 3235.484 TIME= 22:30:45
Preconditioned conjugate gradient solver error level 1. Possibly, the
model is unconstrained or additional iterations may be needed. Try
running setting the multiplier MULT on the EQSLV command to greater
than 1.0 (but less than 3.0).
