SAMCEF for Mechatronics
浏览:3398
q
Mechanical design using SAMCEF
Mecano : Time response of Mechanisms+ Structure(机械结构非线性动力学分析)
Dynam : Modal analysis +Super-element creation(模态分析与超单元建立(模态缩减))
Asef : Linear static analysis(线性静力学分析刚度分析)
Repdyn : Harmonic response(线性FRFS分析,可用于分析动柔度)
q
Control design using MATLAB Simulink (机电联合仿真分析)
q
Integration of Mechanical design (mechanisms + structure) andcontroller design : import of MATLAB Simulink controller inside SAMCEFMecano (在SAMCEF Mecano中完成机电联合仿真分析
Optimizationof parameterized mechatronic systems using BOSS quattro (在BOSS quattro中完成机电系统参数化优化设计)
