后处理求助
浏览:14297 回答:1
后处理弹出信息如下: Date: 09/04/2015 Time: 17:41:32
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version : ls971s R5.0 Date: 04/10/2010 |
| Revision: 59419 Time: 10:11:54 |
| Features enabled in this version: |
| Shared Memory Parallel |
| ANSYS Database format |
| Licensed to: |
| Platform : WIN32 |
| OS Level : Pro SP1 B7601sta/7 SRV 2003/2008 |
| Compiler : Intel Fortran Compiler 10.1 |
| Hostname : PC-20141211OHEK |
| Precision : Single precision (I4R4) |
| SVN Version: 59824 |
| Unauthorized use infringes LSTC copyrights |
Input file: F:/anson/DF/22/18307-~1.DYN
The native file format : 32-bit small endian
Memory size from command line: 131072000
JOBID : 18307-4-4
Memory option : AUTO selected
expanding memory to 131072000 starting ls-dyna
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Finite Element code. *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2010 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 1 beginning of keyword reader
expanding memory to 20720
expanding memory to 97976
expanding memory to 142976
expanding memory to 172976
expanding memory to 364388
expanding memory to 387004
expanding memory to 451224
expanding memory to 499028
expanding memory to 520654
expanding memory to 542156
expanding memory to 562156
expanding memory to 582156
expanding memory to 602156
expanding memory to 622156
expanding memory to 642156
expanding memory to 664518
expanding memory to 715918
Open include file: 18307-4-4.blk
Open include file: 18307-4-4.mod
expanding memory to 736916
expanding memory to 852788
expanding memory to 874692
expanding memory to 918038
Memory required to process keyword : 918038
contracting memory to 1 end of keyword reader
LS-DYNA will perform a structural only analysis
untitled-1
ls-dyna ls971s.59419 R5.0 date 04/10/2010
请教各位,这是我的步骤有问题还是软件装的有问题呢
tangcarlos
应该是安装破解没有彻底。
2015年9月22日
