- 技术邻 >
- CAE仿真 >
- HyperWorks
自己画得一个实体,做静力线性分析时,出现下列ERROR#1237,求高手帮忙解决,非常感谢!
浏览:127501 回答:7
** OptiStruct 10.0 **
** Design and Optimization Software **
** from Altair Engineering, Inc. **
** Windows XP Professional SP3 (Build 2600) WWW-4B46AD9643E **
** 2 CPU: Pentium(R) Dual-Core CPU T4300 @ 2.10GHz **
** CPU speed 2100 MHz **
** 1066 MB RAM, 3935 MB swap **
** Build tag: 0466938_5333O00_Ci3242M-000 14000 **
** COPYRIGHT (C) 1996-2009 Altair Engineering, Inc. **
** All Rights Reserved. Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering, Inc. **
** Decompilation or disassembly of this software strictly prohibited. **
*** OptiStruct defaults set from:
install config file: D:\Hyperworks10/hwsolvers/hwsolver.cfg
NOTE # 1929
Created RAM scratch area: total size 200 MB.
*** ERROR # 1237 ***
CQUAD4 element number 8039 references
a missing or invalid property number 3.
CQUAD4 element number 8045 references
CQUAD4 element number 8048 references
CQUAD4 element number 8049 references
CQUAD4 element number 8050 references
CQUAD4 element number 8051 references
CQUAD4 element number 9900 references
CQUAD4 element number 9901 references
CQUAD4 element number 9902 references
CQUAD4 element number 9903 references
CQUAD4 element number 9904 references
CQUAD4 element number 9905 references
CQUAD4 element number 9906 references
CQUAD4 element number 9907 references
CQUAD4 element number 9908 references
CQUAD4 element number 9909 references
CQUAD4 element number 9910 references
CQUAD4 element number 9911 references
CQUAD4 element number 9912 references
*** More of ERROR messages # 1237 were suppressed...
*** ERROR # 14 ***
34 errors found in the input data.
RESOURCE USAGE INFORMATION
MAXIMUM MEMORY USED 211 MB
THIS INCLUDES 200 MB RAMDISK AREA ALLOCATED IN MEMORY
MAXIMUM DISK SPACE USED 0 MB
COMPUTE TIME INFORMATION
EXECUTION STARTED Sun May 20 17:17:29 2012
EXECUTION COMPLETED Sun May 20 17:17:29 2012
ELAPSED TIME 00:00:00
CPU TIME 00:00:00
*** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
***** END OF REPORT *****
For Useful OptiStruct Tips and Tricks, go to the URL:
http://www.altairhyperworks.com/tips.aspx
Following error/warning messages appeared too many times
and were suppressed:
1237
Total of 15 repeat error message(s) were suppressed.
To see more messages use "MSGLMT" control card in the data or config file.
There were 34 error messages during input processing.
The first message is repeated below:
NOTE # 1929
*** ERROR # 14 ***
CPU TIME 00:00:00
1237
