球大神帮忙!!hyperworks计算时是不是要占用c盘空间??
浏览:148430 回答:2
A fatal error has occurred during computations:
*** ERROR # 151 ***
Error accessing the scratch files:
error encountered in subroutine "xdseex"
Solver error no. = -710
index = 1
This may be caused by insufficient disk space or some other
system resource related limitations.
(e.g. The Operating System or NFS cannot handle file size > 2 GB.)
This error was detected in subroutine splncz4.
球大神帮忙!!!!
把文件保存在空间比较大的盘 然后计算
2014年4月6日
钱平
计算过程中会有缓存文件,所以建议保存路径放在空间比较大的硬盘里面
2014年4月3日
